I need help
Hai Tran 0 Reputation points
2026-09-18T08:31:22.39+00:00
what the hell User's image
happen here i try all any suggest on your support but nothing happen
  1. DaveM121 935.7K Reputation points Independent Advisor
    2026-09-18T09:05:35.9733333+00:00
    If the usual command prompt methods to fix the Store app are not resolving the problem, the best option to resolve the errors in the Store app and Windows security is to open the Settings App.
    Go to System - Recovery.
    Click the 'Reinstall Now' button in the 'Fix problems with Windows Updates' section, then wait for that process to complete.
    This process does not affect your files, settings or installed updates.
  2. Hai Tran 0 Reputation points
    2026-09-19T07:39:32.8733333+00:00
    it's not solve anything
  3. DaveM121 935.7K Reputation points Independent Advisor
    2026-09-20T05:15:34.54+00:00
    Sorry, I was offline, if that process did not resolve the problem, click your Start Button, then just type winver and press Enter.
    Please provide a screenshot of the resulting dialog box.
