Power BI Learning
Sapna Sarke 0 Reputation points
2026-09-18T07:40:42.9733333+00:00
There are multiple module for Power BI in Learn MS but what's the right order to read and learn as a beginner
    2026-09-18T07:41:01.79+00:00
    A good beginner order is to follow the learning paths from fundamentals to hands-on report building, then move into data preparation and sharing.
    Recommended order:
    1. Start with Power BI fundamentals
      Read Describe the capabilities of Microsoft Power BI to understand the business value, core components, dashboards, reports, visualizations, data cleaning, and AI insights.
    2. Learn the basic Power BI workflow
      Continue with Get started building with Power BI. This covers how Power BI services and applications work together, the building blocks of Power BI, and how to create interactive reports.
    3. Learn how to use the Power BI service as a consumer
      Study Explore what Power BI can do for you to learn how to find dashboards, reports, and apps, view and export data, use filters, subscribe to reports, set alerts, and collaborate.
    4. Practice a beginner learning path end to end
      Use Get started with Power BI as an entry-level path. It combines the consumer view and report-building basics and has no prerequisites.
    5. Move to report creation and usage
      After the basics, take Create and use analytics reports with Power BI. This introduces a broader sequence: building with Power BI, modeling data, exploring data, and publishing and sharing reports.
    6. Learn data preparation
      Next, study Prepare data for analysis with Power BI. This focuses on Power Query, retrieving data from sources, cleaning and transforming data, loading data, and choosing a model framework.
    7. Expand into full report design and visualization
      Then take Prepare and visualize data with Microsoft Power BI. This path covers connecting to data, transforming and shaping data, configuring a semantic model, designing effective reports, and an introduction to Copilot in Power BI.
    If a single starting path is needed, this is the simplest sequence:
    • Get started with Power BI
    • Create and use analytics reports with Power BI
    • Prepare data for analysis with Power BI
    • Prepare and visualize data with Microsoft Power BI
    If learning only with local files at first, Power BI Desktop is enough to practice core skills such as data transformation, modeling, DAX, and visualization. Cloud features such as publishing, sharing, and some service-based scenarios come later.
  2. Marcin Policht 109.5K Reputation points MVP Volunteer Moderator
    2026-09-18T11:45:51.9833333+00:00
    Incidentally, this has already been answered on this forum. Pls refer to https://learn.microsoft.com/en-gb/answers/questions/5990112/proper-sequence-of-power-bi-learning-modules
    The simplest way is to follow the learning path pages instead of collecting individual modules manually, because the learning paths already group modules in a recommended sequence.
    For Power BI, the context shows these common progression options:
    1. Start with fundamentals
      • This is a beginner learning path with no prerequisites.
      • It includes:
        • Explore what Power BI can do for you
        • Get started building with Power BI
    2. Then move to data preparation and reporting
      • This beginner path expects familiarity with data and analytics concepts.
      • It covers getting data, cleaning and transforming data, configuring a semantic model, designing reports, and getting started with Copilot in Power BI.
    3. Then move to more focused intermediate topics depending on goals
      • Prepare data for analysis with Power BI for Power Query, data retrieval, cleaning, loading, and model framework choices.
      • Build Power BI visuals and reports for report design, filters, user experience, visual calculations, and analytics.
      • Prepare data for tabular models in Power BI for enterprise-scale modeling and scalability. This path recommends prior knowledge of Power BI data model design, star schema basics, and DAX basics.
    If the goal is to arrange selected modules in proper order, use this rule:
    • Complete Beginner paths before Intermediate paths.
    • Complete any path with no prerequisites before paths that list recommended prior knowledge.
    • When modules overlap, keep the broader foundation first, then the specialized path.
    A practical order from the available content is:
    1. Get started with Power BI
    2. Prepare and visualize data with Microsoft Power BI
    3. Prepare data for analysis with Power BI
    4. Build Power BI visuals and reports
    5. Prepare data for tabular models in Power BI
    If modules were already bookmarked individually, a cleaner way to keep them in order is to start from the main learning path page and continue from there. A related Microsoft Q&A answer also recommends bookmarking the main path page rather than individual modules, and using Collections to organize the full path in one place.
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    hth
    Marcin
