How to fix top section of word document
YASMIN CHARLES 0 Reputation points
2026-09-18T03:22:14.69+00:00
Screenshot 2026-09-18 at 13.02.50
Whenever I enter full screen, the top functions turn white, and so does the document name. It has happened since I just updated it. Any fix for this? I tried toggling the colourful and aluminium themes and only the aluminium one works.
Microsoft 365 and Office | Word | For education | MacOS
  1. Michelle Nguyen 1,750 Reputation points Independent Advisor
    2026-09-18T04:09:48.1066667+00:00
    Hi @YASMIN CHARLES
    Based on the information you provided, I understand that after updating Word for Mac, the icons and document name in the top section become white and nearly unreadable when you enter full-screen mode. The issue appears to occur with the Colorful theme, while the Aluminum theme works normally.
    I tested this in my environment and was able to reproduce the same behaviour.
    Screenshot 2026-09-18 at 11.05.12
    However, before proceeding, could you please provide your current Word version and build number, as well as your macOS version? You can find the Word version by selecting Word > About Microsoft Word.
    Also, could you let me know where you downloaded Word? You may try uninstalling the current version and installing the previous version from the link below to check whether the same issue still occurs:
    Update history for Office for Mac
    I tested the previous version, and everything displayed normally. Therefore, you may consider rolling back to version 16.112.4 to see whether the issue is resolved.
    Screenshot 2026-09-18 at 11.22.14
    Before uninstalling Word, please make sure that your documents are saved and that you have the necessary Microsoft 365 account or licence information to reinstall and activate the application.
    Please let me know the results or share any updates, and I will be happy to assist you further.
