camera not working
Cecilia Haynes 0 Reputation points
2026-09-17T18:23:44.0366667+00:00
the camera on my laptop is very blurry, i cant even be seen on teams
Microsoft Teams | Microsoft Teams for education | Meetings and calls | Audio and video
  1. Levi Cornwell 255 Reputation points
    2026-09-17T18:41:28.7333333+00:00
    If the camera is blurry even outside Teams, I'd check the camera itself first.
    Try opening the Windows Camera app and see if the image is also blurry there. If it is, clean the camera lens and check for any privacy shutter or cover that may be partially blocking it.
    If the Camera app looks clear but Teams is blurry, check Teams camera settings and make sure no blur/background effect is enabled. You can also update Windows and the camera driver from Device Manager.
    If it's still blurry in both Camera and Teams after that, the webcam itself could have a hardware or focus issue. Microsoft also recommends testing the camera in another app to determine whether the problem is specific to Teams.
  2. Deleted
