sound problem
anshul baunthiyal 0 Reputation points
2026-09-17T14:09:54.96+00:00
my output sound is not work even i full sound 100% they do not work properly so please kindly help my problem as soon soon as possible my laptop is hp victus
@hp victus
  1. David-M 126.2K Reputation points Independent Advisor
    2026-09-17T14:43:08.87+00:00
    Hi. I'm David, and I'm happy to help you.
    To be able to assist you better, please clarify the following:
    • Are you trying to play audio via internal speakers, external speakers, or headphones?
    • If it is an external speaker or headphones, does it have a standard audio connector (Jack connector) or a USB connector, or is it connected via Bluetooth?
    Also, share a screenshot of your system information.
    • Press "Windows + R", type msinfo32 and press Enter.
    Maximize the window and use the shortcut "Windows + Shift + S" to use the screenshot tool.
    Looking forward to your reply.
