trying to load ChatGPT add in for powerpoint and getting error
Janice Huntingford 0 Reputation points
2026-09-17T11:24:18.9266667+00:00
Error loading addins in PowerPoint for mac. It repeatedly says error loading
Microsoft 365 and Office | PowerPoint | For education | MacOS
  1. Michelle Nguyen 1,510 Reputation points Independent Advisor
    2026-09-17T12:27:26.7866667+00:00
    Hi @Janice Huntingford
    Based on the information you provided, I understand that you are trying to load the ChatGPT add-in in PowerPoint for Mac, but PowerPoint repeatedly displays an "Error loading add-ins" message and the add-in fails to load.
    To help narrow down the cause, could you please provide a bit more information?
    1. Which Microsoft 365 license are you using?
    2. Does the same error occur if you try installing or opening a different add-in from Office Store/AppSource, or is it only happening with the ChatGPT add-in?
    3. What version of PowerPoint for Mac are you currently using?
    4. Which version of macOS is installed on your device?
    In the meantime, here's what's worth trying, in order:
    -Please open PowerPoint, select Home > Add-ins > More Add-ins, and check My Add-ins. If the add-in is listed, try selecting Refresh. If it still cannot be loaded, remove and reinstall it. Microsoft documents Refresh and reinstallation as the next steps when a PowerPoint add-in is unavailable or does not load correctly.
    -After testing the ChatGPT add-in in PowerPoint for the web, everything appears to be working normally. So please try the same add-in in PowerPoint for the web.
    -Check the Mac's date and time System Settings > General > Date & Time, and make sure "Set time and date automatically" is on. Incorrect date/time is a specifically documented cause of "Error loading add-ins" on Mac, since it can break the certificate validation used when Office reaches out to the add-in catalog.
    If the issue is still occurring, please feel free to provide any additional information, and I'll do my best to help you further.
