How to fix pc(Toshiba PC battery and power LED lights blinking but not turning on
VICTOR BAKIM 0 Reputation points
2026-09-17T11:08:26.7166667+00:00
My PC battery got completely dead (the battery health is completely drained) since then I've been using my pc as a desktop only working when there is electricity, long story short some days later when I plug in the charger cable the power and the battery LED lights keep blinking and never turn on
  1. DaveM121 933.5K Reputation points Independent Advisor
    2026-09-17T11:41:47.5566667+00:00
    Remove the power cable from your laptop.
    Press and hold the power button on the case of your laptop for 30 seconds.
    Wait 30 minutes.
    Reconnect the power cable and start your laptop, is there an image on the screen, do you see the Toshiba logo screen and does it boot into Windows?
