Ethernet Connection name amendment
Lethal Lee 30 Reputation points
2026-09-17T05:17:16.1166667+00:00
I attach a screen shot of my adapter settings in the current network.
I am trying to amend the line that is labelled 'Baines - GL - MT6000 - b41 - 5g'.
As this would clearly be a 5G connection to the wi-fi originating on my router.
I have check google advises...and refer to the top label only, apparently.
Appreciate some direct and susinct advise.
regardsethernet name
  1. Carl-L 22,825 Reputation points Microsoft External Staff Moderator
    2026-09-17T09:48:36.15+00:00
    Hello Lethal Lee,
    Welcome to Microsoft Q&A forum.
    As I see, the connection is stated as Ethernet, not Wi-fi. The Baines - GL - MT6000 - b41 - 5g part is just the name of the network, which could be set by the manufacturer to shows what the router is capable of. The upper name "Baines-Ethernet" shows that the connection is an Ethernet connection. You can change the name as you wish, however the connection type won't change.
    I hope this clarifies.
