A region mismatch error can still occur even when both accounts show the same country. Microsoft gift cards and codes are region-restricted: the currency and code must match the Microsoft account’s registered jurisdiction, and the balance cannot be converted to another currency.
Try this redemption path first:
- Redeem on the web instead of the app: go to https://www.microsoft.com/redeem.
- Sign in with the exact Microsoft account that should receive Minecraft.
- Enter the code carefully and complete the prompts.
If the same error appears, the supported next step is to contact Microsoft Support for account/code review. A similar Microsoft Q&A case with the same “different region” error was resolved by directing the customer to Contact Support after confirming the account region.
Also note:
- Microsoft account balance is non-transferable between accounts.
- If the wrong code type was purchased, the retailer must be contacted.
- If the code was bought from a third party, that seller’s return policy applies.
For support, use Contact Microsoft Support.
