network connection
dwallace1@indy.rr.com 0 Reputation points
2026-09-16T20:01:08.2933333+00:00
We are connected to the internet physically but our apps will not recognize the connection.
We have flushed and reset the dns and networking caches.
Windows for home | Other | Internet and connectivity
    2026-09-16T20:01:27.4333333+00:00
    Since DNS and network command resets were already tried, the next supported steps are:
    1. Run the built-in Network troubleshooter:
      • Go to Start > Settings > Network and Internet > Status.
      • Select Network troubleshooter.
      • Follow the on-screen steps and check whether apps start detecting the connection.
    2. Test the same network on another device:
      • If another Windows PC can connect normally on the same Ethernet network, the issue is likely on the original PC.
      • If the second device also fails, the problem is more likely the router, ISP, or Ethernet adapter.
    3. If the PC has Wi-Fi available, connect to Wi-Fi temporarily:
      • This helps confirm whether the issue is limited to Ethernet.
      • If Wi-Fi works and Ethernet does not, focus on the Ethernet adapter or its driver.
    4. Reinstall the Ethernet adapter driver.
      • Risk: this temporarily removes network connectivity until Windows reinstalls the driver or a backup driver is installed.
      • Before uninstalling, download the latest network adapter driver from the PC manufacturer on another device if needed.
      • Open Device Manager.
      • Expand Network adapters.
      • Right-click the Ethernet adapter > Uninstall device.
      • If shown, select Attempt to remove the driver for this device > Uninstall.
      • Restart the PC.
      • After restart, Windows should reinstall the adapter driver automatically.
    5. Use Network reset as the last step.
      • Risk: this removes and reinstalls network adapters and resets their settings to defaults. VPN clients, Hyper-V virtual switches, and similar networking software might need to be reinstalled or reconfigured afterward.
      • In Windows 11: Start > Settings > Network & internet > Advanced network settings > Network reset > Reset now.
      • In Windows 10: Start > Settings > Network & internet > Status > Network reset > Reset now.
      • Restart and test the apps again.
    If the apps lose connectivity only under a local proxy tool, one documented cause is a system proxy intercepting traffic; some apps reject that traffic because of certificate pinning.
