Other issues or features related to Microsoft Edge on Windows 11
I do not want to use the PWA application. How do I get rid of it?
AI answer
To remove a PWA installed through Microsoft Edge:
Another way:
edge://apps.From Windows, a PWA can also be removed like a normal app:
If the app was force-installed by an administrator by using WebAppInstallForceList, users can't uninstall it. In that case, the policy must be removed by the administrator for the PWA to be uninstalled.
In addition to the options provided by the automated answer, you can also right-click the PWA app from the Start menu and select Uninstall. This will uninstall the app directly without any additional prompts or clicks, which is much easier.
