How to fix Teredo Tunneling adapter on Widows 10 desktop?
Be CoxG 0 Reputation points
2026-09-16T17:23:29.62+00:00
It just shows a yellow checkmark next to computer and whn troubleshooting it was unable to reload this adapter.
  1. Ivan B 123.6K Reputation points Independent Advisor
    2026-09-16T18:44:05.37+00:00
    Hi ,
    Check the iphlpsvc registry path:
    1. Press the Search box on the taskbar, type cmd, and then open the Command prompt.
    2. Run the following command from the Admin command prompt:
    reg query HKLM\System\CurrentControlSet\Services\iphlpsvc\Teredo
    If the output includes the following line,
    Teredo has been disabled:
    Type REG_DWORD 0x4
    On the right, open the command prompt (admin) run the commands:
    netsh int teredo set state disable
    netsh int teredo set state type=default
    netsh int teredo set state enterpriseclient
    One at a time, then run Interfarce, take a screenshot and post it here
