How do we enable automatic storage expansion before database disk capacity hits 100% and triggers replica failover?
Michael Johnson 60 Reputation points
2026-09-16T17:02:24.7+00:00
We are dealing with a critical challenge on one of our absolutely vital production database clusters running under heavy transactional load. The primary instance simply hit a wall and was brought to its knees when disk utilization maxed out at 100% capacity, abruptly triggering an emergency failover straight to our read-replica.
I have been digging into the incident logs and telemetry, and it is obvious that manual drive provisioning cannot keep pace with our aggressive data growth. Since we cannot afford another unplanned service disruption on this environment, I would like to hear what the most effective and reliable method is to enable automatic storage expansion, so the storage volume scales seamlessly before running out of headroom and taking down the primary node?
Windows for business | Windows 365 Business
Tracy Le 12,410 Reputation points Independent Advisor
2026-09-16T18:08:55.08+00:00
Hello Michael Johnson,
When database disk capacity hits 100 percent, the primary engine enters a write-lock or read-only panic state, which forces an immediate failover to the read-replica. Preventing this bottleneck requires decoupling capacity scaling from manual administrative tasks by enabling platform-level storage autoscaling or configuring a proactive automation loop at the operating system tier.
If this database runs on a managed cloud service such as Amazon RDS or Azure SQL, navigate to the instance storage settings, enable Storage Autoscaling, and specify a maximum storage threshold. For self-hosted instances on Windows Server virtual machines, set up a scheduled PowerShell task triggered by Windows Performance Counter alerts when free disk space falls below 15 percent. This automation script should call your hypervisor or cloud API to expand the virtual hard disk, followed immediately by running Resize-Partition on the affected volume without taking the service offline.
Remember to align your database file auto-growth settings and verify that IOPS scaling limits do not throttle the underlying storage during concurrent disk expansion.
0 additional answers
