AZ 700 Labs- VM quota issue
Stephen J 0 Reputation points
2026-09-16T12:27:07.2033333+00:00
I am taking the AZ 700 course and following the labs. I have setup the free trial subscription specifically for the LAB.
It seems some of the Labs require more VMs than allowed on my trial subscription, for example the Load balancer lab.
Are there any options to build the course Labs for free on my subscription?
Steve
Azure | Azure Training
  1. Senthil kumar 2,420 Reputation points
    2026-09-17T05:14:26.92+00:00
    Hi @Stephen J
    We understand your concern. I will provide one solution but i am not sure it will be applicable to you but any way you can try it.
    Many AZ‑700 labs have a Cloud Sandbox button that gives you a temporary Azure environment with full quotas, including multiple VMs.
    ✔ 100% free
    ✔ No subscription required
    ✔ No quota limits
    ✔ No credit card
    ✔ No billing risk
    ⚠ Sandbox expires after 4 hours, but you can restart it.
    If your AZ‑700 lab has a “Launch Sandbox” button → use it instead of your subscription.
    Thanks.
