I purchased office 2024 home and installed it on my mackbook, but not able to edit in excell
Sachin Kaushik 0 Reputation points
2026-09-16T12:10:59.92+00:00
I purchased office 2024 home and installed it on my mackbook, but not able to edit in excell.
Microsoft 365 and Office | Install, redeem, activate | For home | MacOS
    2026-09-16T12:11:16.4333333+00:00
    On a Mac, this usually happens when Office is installed from the Mac App Store or the Office 2024 license is not activated correctly. The Mac App Store version requires a Microsoft 365 subscription and does not use a one-time Office Home 2024 license.
    Try this in order:
    1. In any Office app, make sure it is signed in with the same Microsoft account that was used to purchase Office Home 2024.
    2. If Excel was installed from the Mac App Store, remove the Office apps:
      • Close Word, Excel, PowerPoint, and Outlook.
      • Open Finder > Applications.
      • Control-click Word, Excel, PowerPoint, and Outlook, then choose Move to Trash.
    3. Reinstall Office directly from Microsoft, not from the Mac App Store. If needed, use the Mac installer package for Office:
    4. After installation finishes, open Excel and activate it with the Microsoft account that owns the Office 2024 purchase.
    5. If Excel still shows read-only or asks for Microsoft 365, sign out of Excel, restart the Mac, then open Excel and sign in again.
    If Office apps can open and print files but cannot edit, save, or create new files, that is reduced functionality mode and points to an activation issue.
  2. TaoLi 111.6K Reputation points Independent Advisor
    2026-09-16T12:47:51.2266667+00:00
    Hi , could you share the exact message Excel displays when you try to edit? A screenshot would help—please hide any personal information.
    Please also try opening a new blank workbook and typing into a cell. Does editing fail there too, or only in an existing file?
    This will help me narrow down whether the issue is with Office activation or restrictions on a particular workbook.
