How to fix Outlook and MS office not openong issue
Secretary DDGH 0 Reputation points
2026-09-16T07:46:54.0166667+00:00
Message is coming as Outlook has run into an error that is preventing it from working correctly
Microsoft 365 and Office | Install, redeem, activate | Other | Windows
  1. DaveM121 933.8K Reputation points Independent Advisor
    2026-09-16T08:19:07.5233333+00:00
    Before performing this process, please log into your Microsoft account on this link (https://account.microsoft.com/services/) and check to ensure your Office licence or Microsoft 365 subscription is listed correctly on your account.
    Open the Settings App (gear icon on your Start Menu)
    Go to Apps - Installed Apps, then scroll down to find Microsoft Office
    Select that and choose Modify - Online Repair
    That should fix any issues with your Office Installation.
  2. AI answer
    2026-09-16T07:47:12+00:00
    Try these steps in order:
    1. Start Outlook in safe mode to check whether an add-in is causing the crash.
      • Press Windows key + R.
      • Type Outlook /safe and select OK.
      • In Choose Profiles, accept the default profile and select OK.
      • If Outlook opens in safe mode, the issue is likely caused by an add-in.
    2. Disable Outlook add-ins if safe mode works.
      • In Outlook, go to File > Options > Add-ins.
      • At the bottom, make sure Manage shows COM Add-ins, then select Go.
      • Clear all selected add-ins, then select OK.
      • Restart Outlook normally.
      • If Outlook starts, re-enable add-ins one at a time until the problem add-in is identified.
    3. Repair the Office installation.
      • Close all Office apps.
      • Open Control Panel > Programs and Features.
      • Right-click Microsoft Office 2016, Microsoft Office 2013, or Microsoft Office 2010, then select Repair.
      • If the built-in Repair now button in the error dialog does not help, repairing from Windows is the next step.
    4. Create a new Outlook profile if Outlook still does not start.
      • A corrupted Outlook profile can prevent Outlook from opening.
      • Create a new profile by following Create an Outlook profile.
      • Then restart Outlook and select the new profile in the Choose Profile dialog.
      • If Outlook opens normally, the original profile was corrupted.
    5. Repair Outlook data files.
      • Exit Outlook.
      • Run the Inbox Repair Tool (scanpst.exe) and follow the steps in Repair Outlook Data Files (.pst and .ost).
    6. If Outlook freezes or still does not respond, repair the AppData registry path and then repair Office again.
      • Warning: editing the registry incorrectly can cause system problems.
      • Open Registry Editor.
      • Go to: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
      • Double-click AppData.
      • Set Value data to %USERPROFILE%\AppData\Roaming
      • Select OK, exit Registry Editor, and then run Office Repair again.
    7. Check antivirus software.
      • Make sure antivirus definitions are up to date.
      • Outdated or conflicting antivirus software can prevent Outlook from working correctly.
    If the same error appears in Word, Excel, and Outlook, focus first on the Office repair step because the issue may affect the full Office installation.
    References
