Correct dock for adding 2 external monitors
Terri Nelson-Bunge 0 Reputation points
2026-09-15T22:17:36.4433333+00:00
I have a Surface laptop studio model 1964 i7.
What dock would I purchase to add 2 external monitors?
    2026-09-15T22:17:47.23+00:00
    For a Surface Laptop Studio (model 1964), these Microsoft docks support two external monitors:
    1. Surface Dock 2
      • Supports dual 4K at 60Hz with Surface Laptop Studio.
      • Surface Laptop Studio is explicitly listed among the devices supported for up to two displays on Surface Dock 2.
    2. Surface USB4 Dock
      • Supports two 4K monitors at 60Hz through USB-C or HDMI 2.1.
      • For dual 4K support, a device with USB4/Thunderbolt 4 is required.
    If the goal is simply to add 2 external monitors, either dock is suitable. If a newer dock is preferred with USB4/Thunderbolt 4 connectivity and HDMI 2.1, choose Surface USB4 Dock.
  2. S.Sengupta 32,456 Reputation points MVP Volunteer Moderator
    2026-09-15T23:56:25.95+00:00
    Microsoft Surface Thunderbolt 4 Dock
    You would connect:
    Surface Laptop Studio 1964 → one Thunderbolt 4/USB-C cable → Dock
    Then:
    Dock → Monitor 1
    Dock → Monitor 2
