Can I speed up copying large numbers of files?
Gary Graziano 0 Reputation points
2026-09-15T13:47:33.6833333+00:00
I'm running Win 11Pro on a Dell Latitude laptop with 64GB of memory and 1TB hard drive. I've been trying to copy my .mp3 files to a 1TB USB drive. There are about 140GB worth of files. I started copying by genre, and the process kept stalling. Even breaking it down further by artist was extremely slow. I tried installing Fast Copy and Tera Copy, and both of those encounter similar problems. I disabled my antivirus program which helped a little, but I'm wondering if there is something I can tweak in Windows to enable faster copying. (I also tried xcopy and robocopy at both the command prompt and Power Shell, and could not get the commands right.)
  1. Gary Graziano 0 Reputation points
    2026-09-19T14:07:47.6666667+00:00
    Well, a new USB 3.0 drive of sufficient size (256 GB) solved the problem. The entire archive of music, copied in genre increments, took about 8 hours to copy using Tera Copy. For my own peace of mind I'll continue to try to figure out ropbocopy (using a newer 3.0 drive). I hate to be stymied by a computer problem! Thanks for trying to help.
