A powerful email and collaboration platform developed by Microsoft, designed to support enterprise-level communication and productivity. Miscellaneous topics that do not fit into specific categories.
Yes. Based on the behavior described, a shared mailbox matches that setup better than a distribution list.
The key difference is:
- Distribution list / distribution group: mail sent to the group is delivered to each member’s personal inbox. It is mainly for sending one message to many recipients.
- Shared mailbox: multiple people can read and send email from a common address, and replies can appear as if they came from that shared address rather than an individual user.
That means:
- If the requirement is “everyone receives messages in their own inbox”, that matches a distribution list.
- If the requirement is “people can send as the group address”, that matches a shared mailbox.
What was used previously may have involved both behaviors together, but from the documented feature differences:
- A shared mailbox supports a common address such as
******@contoso.comor******@contoso.com, and members can be granted Full Access and Send As permissions. - A distribution group sends incoming mail to members’ personal inboxes, but the context does not describe it as the tool for members to send mail as that shared identity.
Also note:
- A shared mailbox is not designed for direct sign-in to the mailbox account itself.
- An admin must create the shared mailbox and add members.
- If many users access a shared mailbox at the same time, Microsoft notes shared mailboxes are generally better for small groups, and “if more than a few users need to access a Shared mailbox at the same time, consider one of the other options.”
So the IT guidance is correct for the send-as-the-group-address requirement. If the goal is only receive in everyone’s inbox, a distribution list is the simpler option.
