gpt-6-astra usage produced no Cost Management meter for 9 days — while meter backfill and retroactive re-rating are both observable on the same subscription
Naoto NISHII 0 Reputation points
2026-09-14T10:43:47.4333333+00:00
Summary
I ran gpt-6-astra for five days. Azure Monitor recorded 48.7M input tokens. Cost Management has produced zero meters for it, nine days later.
Separately, and on the same subscription, I have now directly observed the two mechanisms that would make this a retroactive charge rather than a free ride: already-posted rows being re-rated, and missing meters being backfilled days later. So this is not "will it be billed?" speculation — I can watch the machinery work on rows I can query.
Environment: MCA Individual subscription, East US 2, deployment gpt-6-astra (model version 2026-09-03, GlobalStandard). Developer support plan.
1. The usage exists in metrics and not in billing
Azure Monitor, ProcessedPromptTokens (PT24H, Total, resource-wide):
Date (JST) Input tokens Billing row in usageDetails
2026-09-04 1,547,632 present (JPY 426)
2026-09-05 12,430,055 no row at all
2026-09-06 9,451,442 present (JPY 161)
2026-09-07 7,639,615 present (JPY 1)
2026-09-08 16,585,426 present (JPY 126)
2026-09-09 3,370,165 present (JPY 307)
Totals for 09-05 .. 09-09: 48,678,711 input / 711,138 output.
Two separate problems are visible here:
  • 09-05 was the single largest usage day in the window, and it has no row of any kind in Microsoft.Consumption/usageDetails. Later days posted normally, so this is not simple lag — the pipeline moved past it.
  • Across the whole month, 22 meters and 110 rows, no meter for gpt-6-astra exists on any day. Not a zero-cost row; no row.
At the published Global Standard rates ($10 input / $50 output per 1M) this is roughly USD 522. The GA announcement lists full pricing and does not mention an introductory free period, so I do not believe this is intentional.
2. Already-posted rows get re-rated retroactively (observed 2026-09-12)
I pulled usageDetails twice on the same day, same filter, 10 hours apart. Row count, meter count and every quantity were identical. Only payGPrice changed — and it changed on rows for 09-01 .. 09-10 that had already posted.
gpt-5.6-sol, USD per 1M:
Inp Cd Inp Cd Wr Opt
ShortCo, 12:30 5 0.5 6.25 30
ShortCo, 22:50 4 0.4 5 20
LongCo, 12:30 10 1 12.5 45
LongCo, 22:50 8 0.8 10 30
−20% on input, −33% on output, applied backwards over the whole month. Only the eight gpt-5.6-sol meters moved; luna / terra / Grok / Kimi / Claude were untouched. In my case this went in the customer's favour, but the point is that posted cost rows are not final.
3. Missing meters get backfilled days later (observed 2026-09-13)
Grok 4.6 had been posting a Cached meter only — the plain input and output meters were absent. On 09-13, two rows appeared dated 09-08, five days in the past:
Date Meter Quantity JPY
09-08 4.6 Inp Glbl Tokens 0.011 (1K) 0.0035
09-08 4.6 Outp Glbl Tokens 0.001 (1K) 0.0010
09-08 previously had no credit-eligible row at all. The amounts are trivial; the mechanism is not.
This is still going. Same query, same window, three consecutive days:
Pulled Rows Latest usage date present
09-12 106 09-10
09-13 108 09-10
09-14 110 09-10
Rows keep being inserted into days that already reported, while the leading edge has not advanced since 09-10 — a four-day lag as of today.
4. Why I am asking rather than waiting
Given (2) and (3), the absence of gpt-6-astra meters cannot be read as "not billed". The obvious reading is that ~USD 522 is queued to land on days that currently look settled. My remaining free credit is about JPY 13,000, so a backfill of that size lands as a real charge with no warning.
I deleted the deployment on 09-09 to cap the exposure. I am not asking for a credit — I am asking what the meters are going to do.
Questions
  1. Is gpt-6-astra metering currently broken, or is there an unannounced free period for it? If the meters are simply missing, is a backfill queued?
  2. If a backfill posts, will it be charged retroactively, and is there any way to be notified of the amount before it appears?
  3. Why does the 09-05 row not exist at all, when 09-06 through 09-10 posted normally?
  4. When cache-input and cache-write meters do post for gpt-6-astra, will they use the cached rates rather than full input rate? The GPT-5.6 thread below reports cached tokens billed at the non-cached rate.
Reproduction, for anyone wanting to check their own subscription — the Cost Management query API rate-limits hard, but usageDetails returns per-row quantity, payGPrice and isAzureCreditEligible, which is what makes the re-rating visible:
GET https://management.azure.com/subscriptions/{sub}/providers/
    Microsoft.Consumption/usageDetails?api-version=2024-08-01
    &$filter=properties/usageStart ge '2026-09-01'
             and properties/usageEnd le '2026-09-30'
Snapshot it daily and diff payGPrice and the row set. Both of the effects above show up in the diff and in no other view.
Related, and the reason I am posting here rather than only in a support case: "GPT-5.6 Series - Be careful with your Cost Management!" https://learn.microsoft.com/en-ie/answers/questions/5952298/ — same family of symptoms (1-2 week lag, retroactive bulk posting, cached tokens billed at full input rate), and that thread took about seven weeks to resolve.
I have three billing support cases on this. Two were closed without investigation as "Non-CSS Misroute"; the third was answered this week with a request to purchase a Standard plan and refile under the technical category. I can provide case numbers and the full daily metric export on request.
Azure OpenAI in Foundry Models
  1. Deleted
