Power BI training
David Jones 0 Reputation points
2026-09-13T22:46:18.1866667+00:00
Which online courses should I take to fast-track to Power BI skills for Data Analytics?
    2026-09-13T22:46:31.62+00:00
    For a fast-track path to Power BI skills for data analytics, take the learning content in this order:
    1. Get started with Microsoft data analytics
      Best starting point for understanding the data analyst role and how Power BI fits into analytics work.
    2. Prepare and visualize data with Microsoft Power BI
      Strong beginner path for connecting to data, transforming and shaping data, creating visuals, configuring a semantic model, and getting started with Copilot in Power BI.
    3. Prepare data for analysis with Power BI
      Focuses on Power Query, retrieving data from different sources, cleaning and transforming data, profiling columns, and choosing a model framework.
    4. Create and use analytics reports with Power BI
      Covers report building, modeling data, exploring data, and publishing and sharing reports.
    5. Manage workspaces and semantic models in Power BI
      Important once the basics are covered. Adds publishing, workspace management, refresh management, dashboards, and row-level security.
    If a structured instructor-led option is preferred, Design and manage analytics solutions using Power BI (PL-300T00-A) is a focused 3-day course aligned to the Microsoft Certified: Power BI Data Analyst Associate certification.
    If hands-on workshop learning is preferred, Dashboard in a Day - Online workshop is a good practical supplement for building a first model, creating reports, publishing to the Power BI service, and collaborating.
    A practical fast-track sequence is:
    • Start with Get started with Microsoft data analytics
    • Then complete Prepare and visualize data with Microsoft Power BI
    • Then Prepare data for analysis with Power BI
    • Then Create and use analytics reports with Power BI
    • Finish with Manage workspaces and semantic models in Power BI
    • Add PL-300T00-A if certification-focused
  2. Marcin Policht 107.5K Reputation points MVP Volunteer Moderator
    2026-09-14T03:20:47.05+00:00
    Complete the core learning paths designed for the Microsoft Certified: Power BI Data Analyst Associate credential.
    This includes:
    • Get started with Microsoft data analytics: A quick introductory path that introduces the core concepts of data analysis and the Power BI environment.
    • Prepare data for analysis with Power BI: Teaches you how to profile, clean, and load data using Power Query.
    • Model data with Power BI: Focuses on building scalable data models, establishing relationships, and optimizing performance.
    • Design effective reports in Power BI: Covers best practices for creating impactful visuals, interactive dashboards, and customized report layouts.
    • Manage and secure Power BI: Explains how to deploy, share, and secure datasets and workspaces within an organization.
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    hth
    Marcin
