i cannot my word and power point
mohammad ibrahim 0 Reputation points
2026-09-13T19:43:11.2033333+00:00
when i try to open microsoft word or power point that time a notification comes. this notification shows that my wor or power point has run into an error that is preventing it from work correctly
Microsoft 365 and Office | Install, redeem, activate | Other | Windows
    2026-09-13T19:43:27.79+00:00
    Try these steps in order:
    1. Update Office
      • Open any Office app if possible.
      • Go to File > Account.
      • Under Product Information, select Update Options > Update Now.
      • If Update Now is not shown, select Enable Updates first.
    2. Start Word or PowerPoint in Safe Mode
      • Press Windows key + R to open Run.
      • For Word, type: winword /safe
      • For PowerPoint, type: powerpnt /safe
      • Press Enter.
      • If the app opens in Safe Mode, the title bar should show Safe Mode.
    3. If the app opens in Safe Mode, disable add-ins
      • In the app, go to File > Options > Add-Ins.
      • In the Manage list, select the app add-ins or COM Add-ins, then select Go.
      • Clear one add-in, select OK, then restart the app normally.
      • Repeat until the problem add-in is found.
      • Older add-ins such as Abbyy FineReader, PowerWord, and Dragon Naturally Speaking are known to cause problems.
    4. If the app does not open in Safe Mode, repair Office
      • Open Control Panel.
      • Go to Programs > Programs and Features.
      • Select Microsoft Office or Microsoft 365.
      • Select Change.
      • Run Quick Repair first.
    5. If Quick Repair does not fix it, run Online Repair
      • Open Settings > Apps.
      • Find Microsoft Office.
      • Select it, then choose Modify > Online Repair.
      • This is more complete than the Repair Now button in the error dialog and can reinstall Office.
    6. If Online Repair still does not fix it
      • Restart the PC.
      • Then uninstall and reinstall Office.
    If a specific Word, Excel, or PowerPoint file is damaged, try:
    • File > Open > Browse
    • Select the file
    • Select the arrow next to Open
    • Choose Open and Repair
    If PowerPoint shows “Can’t read file” or “Presentation cannot be opened”, the file may be blocked:
    • In File Explorer, right-click the file > Properties
    • If Unblock appears, select Unblock > Apply > OK
    • Then open the file again
  2. EmilyS726 267K Reputation points Independent Advisor
    2026-09-13T20:15:23.58+00:00
    Go to Settings > Apps > Installed Apps.
    Look for Microsoft 365, click on the three dots. Choose Modify, then choose Online Repair.
    If Online Repair doesn't help, uninstall it.
    Restart the computer.
    Then reinstall.
    Please go to https://www.office.com
    Sign into the Microsoft account you used for the subscription. Click on the 9-dot icon on the upper left > More apps.
    Then on the upper right, click on "Install apps". This will now download the installer file. Once downloaded, click on the file to install. It will install the Desktop version of the apps for you then.
    https://support.microsoft.com/office/download-install-or-reinstall-microsoft-365-or-office-2024-on-a-pc-or-mac-4414eaaf-0478-48be-9c42-23adc4716658
    See if it helps.
  3. mohammad ibrahim 0 Reputation points
    2026-09-13T20:22:26.7933333+00:00
    it only shows this when i try to open wordScreenshot 2026-09-03 013314
    s
