Setting to turn OFF Monitor
Phillip Richcreek 995 Reputation points
2026-09-13T17:47:27.14+00:00
I have a Samsung Monitor LS27D39xG. In the past it would turn off automatically after a period of inactivity. Now it never turns off automatically. I've haven't timed the interval after which the monitor turns off, but I believe it's between 15 and 30 minutes.
Is there a setting that would control the length of the interval?
Thanks for your help,
PR
  1. Ivan B 123.5K Reputation points Independent Advisor
    2026-09-13T18:25:30.4266667+00:00
    You can configure this via Control Panel > Hardware and Sound > Power Options > Choose when to turn off the display.
    Set it up according to your preference.
    Or
    Start menu > settings > system > power > Screen sleep and hibernate timeouts
    You can also configure the monitor itself using the "Off-time Plus" feature described in the manual.
    https://www.samsung.com/ie/support/model/LS27D390GAUXXU/
    While this is not a Microsoft website, it is the official site of [Samsung/LS27D39xG].
    Please consider rating the question (accepting the answer or not) and visiting the Microsoft Q&A community if you have further questions.
    Thanks.
  2. Phillip Richcreek 995 Reputation points
    2026-09-13T22:27:44.1666667+00:00
    I think Control Panel > Hardware and Sound > Power Options is what I want but it doesn't offer an option to save changes. monitor settings
    Do I need to click Change advanced power settings?
    PR
  3. Ivan B 123.5K Reputation points Independent Advisor
    2026-09-13T22:31:07.91+00:00
    You can go to > Change advanced power settings > Display > Turn Off Display after > and change the settings.
    Or
    Change it to 4 minutes to see if the save option appears; save it, then change it to 5 minutes and save again.
    Thanks.
  4. Phillip Richcreek 995 Reputation points
    2026-09-13T22:43:10.4966667+00:00
    Ivan,
    I'm don't know what I did wrong, but the response I want to your initial question is above "I think Control Panel > Hardware and Sound > Power Options is what I want but it doesn't offer an option to save changes."
    PR
  5. Ivan B 123.5K Reputation points Independent Advisor
    2026-09-13T22:45:45.15+00:00
    If it doesn't appear in the options panel where you can make the changes I described above...
    Thanks.
