Welcome Richard Blakey,
Thanks for reaching out to Microsoft Q&A Forum. I understand that your audio input and output devices are missing, and Windows cannot find an audio device to connect to.
Since the previous reply already asked about the device model, recent changes, and what appears in Device Manager, could you please let us know:
- Do you see any devices listed under System devices with a warning icon?
- Are the audio devices missing only from Windows, or are they also unavailable in the BIOS/UEFI diagnostics (if your manufacturer provides them)?
In the meantime, you can try these steps:
Option 1: Restart the Windows Audio services
- Press Windows + R, type
services.msc, and press Enter - Locate Windows Audio and Windows Audio Endpoint Builder
- Ensure both services are Running
- If not, right-click and select Start
Option 2: Check for hidden audio devices
- Open Device Manager
- Select View > Show hidden devices
- Expand Sound, video and game controllers
- Remove any greyed-out audio devices and restart the PC
Option 3: Reinstall the audio controller
- In Device Manager, expand System devices
- Locate the audio controller (such as Intel Smart Sound Technology, Realtek Audio, or similar)
- Right-click and select Uninstall device
- Restart the computer
If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
