A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
For OneNote on Windows, this sharing problem is commonly fixed based on where the notebook was created and stored.
If the error appears when sharing a notebook that is already on OneDrive, the usual cause is that the notebook was created by using File > New > Browse to a OneDrive location instead of creating it directly with the OneDrive option.
Use the matching fix below:
- If the notebook has not been created yet
- In OneNote 2016 for Windows, select File > New > OneDrive.
- Create the notebook there.
- Then share it from File > Share.
- If the notebook already exists
- Open the notebook in OneNote 2016 for Windows.
- Select File > Share.
- When the message appears, select OneDrive, then Browse.
- Create a new folder, or choose a different location in OneDrive that is not the notebook’s current location.
- Select Move.
- After the notebook location changes, try sharing again.
If the notebook is being shared from OneDrive or SharePoint and the error says organizational policies do not allow sharing, external sharing may be turned off. In that case, a SharePoint or Microsoft 365 admin must check:
- Microsoft 365 admin center > Admin centers > SharePoint > Policies > Sharing
- For OneDrive sharing: Admin centers > OneDrive > External sharing
If admin permissions are not available, the SharePoint administrator or Microsoft 365 administrator must make that change.
