camera not wroking
deekshitha k v 0 Reputation points
2026-09-13T03:27:34.3466667+00:00
my ASUS laptop camera not working showing error
ERROR : 0xA004244<No cameras are Attached>
    2026-09-13T03:27:51.96+00:00
    Try these steps in order for 0xA00F4244<NoCamerasAreAttached> on an ASUS laptop:
    1. Check for a physical camera block.
      • On many ASUS laptops, a function key can turn the webcam on or off.
      • Look for a camera icon on the F1F12 keys and press that key, or Fn + that key.
      • Also check for a privacy slider or shutter near the camera lens and make sure it is open.
    2. Make sure Windows camera access is enabled.
      • Open Settings > Privacy & security > Camera.
      • Turn on Let apps access your camera.
      • If using Teams, also make sure Microsoft Teams (work or school) is turned on.
    3. Run the Windows camera troubleshooter.
      • Open Settings > System > Troubleshoot > Other troubleshooters.
      • Find Camera and select Run.
    4. Check Device Manager for a hidden or disabled camera.
      • Open Device Manager.
      • Select View > Show hidden devices.
      • Select Action > Scan for hardware changes.
      • If Cameras or Imaging devices appears, right-click the camera and select Enable device if available.
    5. Reinstall the camera device.
      • In Device Manager, expand Cameras.
      • Right-click the camera and select Uninstall.
      • Restart the laptop so Windows reinstalls the camera.
    6. Install the ASUS camera driver.
      • If the camera still does not appear, download and install the webcam driver for the exact ASUS model from the ASUS support site, then restart.
    7. If the camera appears only sometimes, try basic camera driver mode.
      • Open Settings in Windows.
      • Go to the camera settings for the device.
      • Open Advanced camera options.
      • Enable Basic camera driver mode.
      • Restart Teams or test the Camera app again.
      • Note: this can disable some manufacturer camera features, but it can improve reliability.
    8. If none of the above works, the issue is likely hardware-related.
      • The accepted guidance for this error indicates that if the camera still does not appear after privacy checks, troubleshooting, rescanning hardware, and reinstalling the manufacturer driver, the device may need manufacturer service.
  2. Jhun Buala 5,710 Reputation points Independent Advisor
    2026-09-13T04:15:08.5633333+00:00
    Hi Deekshitha,
    Good day. Your 0xA00F4244 / 0xA004244 error usually means Windows isn't detecting or accessing the built-in camera. Try these steps first:
    1. Check the camera shutter-privacy switch. If your ASUS has a physical camera cover or camera hotkey, make sure the camera is enabled.
    2. Check your camera permissions. Go to Settings > Privacy & security > Camera and make sure Camera access and Let apps access your camera are turned on.
    3. Check Device Manager. Right-click Start > Device Manager, then expand Cameras or Imaging devices.
      • If the camera is listed, right-click it and choose Enable device or Update driver.
      • If it's missing, Windows may not have the correct ASUS camera driver.
    4. Install the ASUS camera driver. Go to ASUS Support, search for your exact laptop model, and install the latest Camera driver, then restart the laptop.
    Hope this make it work.
    Regards,
    Jhun
  3. Kapil Arya 38,446 Reputation points Volunteer Moderator
    2026-09-13T07:21:46.0333333+00:00
    Looks like the Camera device is missing in Device Manager.
    You may be able to install it from your device manufacturer's website.
    Additionally. refer suggestions in this support article: https://support.microsoft.com/en-us/windows/camera-doesn-t-work-in-windows-32adb016-b29c-a928-0073-53d31da0dad5
