A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
Yes. Similar issues have been reported with Excel for the web where a spreadsheet stops loading across browsers and shows repeated refresh or webpage errors.
Try these steps in order:
- If the file is locked, make sure it is closed on all devices.
- If the file was left open elsewhere or did not close properly, Excel can block access.
- Wait a few minutes and try again so the server can release the lock.
- If the file is shared, check whether another person has it open.
- Open it as read-only if available.
- If needed, ask the other user to close it, check it in, or grant edit access.
- If only view access is available, use Viewing > Request more access.
- If the problem is with Excel for the web across multiple browsers, reset the network on the affected Windows PC.
- Go to Start > Settings > Network & Internet > Advanced network settings > Network Reset > Reset now.
- This is a system-level change and will remove and reinstall network adapters, so saved network settings may need to be re-entered.
- If desktop Excel opens to a blank screen, try these checks:
- In Excel, go to View > Unhide and see whether the workbook was saved with hidden sheets.
- Minimize Excel, then restore it from the taskbar to refresh the window.
- Reset the file association for the workbook type in Windows by right-clicking the file > Properties > Change under Opens with, then select the correct app and enable Always use this app.
- Repair Microsoft 365.
- An Online Repair is recommended for blank-screen and not-responding Excel issues.
- If repair does not help, continue to support options in the support article.
- Install the latest Microsoft 365 and Windows updates.
- Out-of-date files can cause Excel hangs, freezes, and loading problems.
- If Excel desktop is hanging, test in Safe Mode.
- Safe Mode bypasses Excel add-ins and custom startup settings, which can interfere with opening workbooks.
- If the issue continues, use guided troubleshooting or Microsoft Support.
- The support content specifically recommends guided support for Office problems and contacting Microsoft Support if the issue remains after the listed steps.
- Excel file is locked for editing
- Online Excel spreadsheet stopped working. It shows a message saying "The webpage at https:... might be temporarily down or it may have moved permanently to a new web address." - Microsoft Q&A
- Troubleshoot opening a blank screen when you double-click a file icon or file name in Excel
- Excel opens to a blank screen
- Excel not responding, hangs, freezes or stops working
