A family of System Center products that provide infrastructure monitoring, help ensure the predictable performance and availability of vital applications, and offer comprehensive monitoring for datacenters and cloud, both private and public.
For SCOM 2022 UR4, one documented fix is “Management Packs not updated/imported after install.” If reporting categories are present but the reports themselves are missing after UR4, the first corrective path is to make sure the reporting management packs were actually imported successfully.
Use this order:
- Verify UR4 is installed on the reporting-related roles
- Management Server
- Reporting
- Web Console / Console as applicable
- UR4 version shown in the environment should be 10.22.12369.0.
- Reapply the correct UR4 MSP packages from an elevated command prompt
Apply the MSP that matches each installed role:
KB5120166-amd64-Server.msp -
KB5120166-amd64-Reporting.msp -
KB5120166-amd64-Console.msp -
KB5120166-amd64-WebConsole.msp
- Manually verify or import the reporting management packs
UR4 includes updated reporting-related MPs such as:
Microsoft.SystemCenter.DataWarehouse.Library.mp -
Microsoft.SystemCenter.DataWarehouse.Report.Library.mp -
Microsoft.SystemCenter.DataWarehouse.Reports.mp -
Microsoft.SystemCenter.OperationsManager.Reports.2007.mp
- If the management server update hit an MP import problem, mitigate it and rerun/import manually
Earlier SCOM 2022 UR guidance documents a known management pack import failure during management server update and gives these mitigations:
- Install .NET Framework 3.5, then rerun the management server update, or
- Import the management packs manually
- If reports are still blank or inconsistent after the MPs are present, check Data Warehouse write health
On all management servers, review the Operations Manager event log for:
- HealthService 2115 events, or
- warning/error events from source Health Service Modules and category Data Warehouse
OperationsManagerDW, reporting behavior can be incomplete or unpredictable. - If UNIX/Linux monitoring was part of the UR4 change, update those MPs separately after UR4
The UR4 process for UNIX/Linux is:
- Apply UR4
- Download the updated Linux/UNIX management packs
- Import the updated MPs
- Upgrade agents with
Update-SCXAgentor the UNIX/Linux Agent Upgrade Wizard
A practical end-to-end fix path for this case is:
- Re-run the UR4 MSPs for Management Server and Reporting from an elevated command prompt.
- In the Operations console, confirm the reporting MPs listed above are imported and at 10.22.12369.0.
- If they are missing, import them manually.
- Then check management server event logs for 2115 or Data Warehouse errors if reports still do not populate.
