STOCKHISTORY function not working
Arne 5 Reputation points
2026-09-11T08:31:49.32+00:00
I’m having trouble with the Excel STOCKHISTORY function.
I’m trying to use STOCKHISTORY to retrieve historical stock prices in two ways:
  1. Pull a time series of historical prices between two dates.
  2. Pull the stock price for an individual date, where the date is linked to a date stored in a cell.
Neither seems to work correctly. In particular, when I use a cell reference for the date rather than entering the date directly in the formula, I don't get the expected result.
For example, I would like to be able to use something along the lines of:
=STOCKHISTORY("AAPL",A1,B1)
where A1 and B1 contain the start and end dates, and also retrieve the value corresponding to a specific date in a cell.
Is this a general issue with STOCKHISTORY, or is it specific to my workbook or Excel installation? Is there a recommended way to make it work with dates referenced from cells?
Thanks!
  1. Darren Bruce 1,395 Reputation points Independent Advisor
    2026-09-11T09:03:27.15+00:00
    Dear @Arne,
    Based on your description, STOCKHISTORY should support cell references for both the start_date and end_date arguments, so a formula such as: =STOCKHISTORY("AAPL",A1,B1) is expected to work, provided that A1 and B1 contain valid Excel date values and not text strings. According to the function documentation, date arguments can be entered directly, generated by a formula such as TODAY(), or referenced from a cell containing a date.
    If the formula works when dates are typed directly into STOCKHISTORY but fails when referencing cells, I recommend checking the following:
    1/Verify that the cells contain actual Excel dates:
    =ISNUMBER(A1)
    A result of TRUE indicates that Excel recognizes the value as a date serial number.
    2/Temporarily format the date cells as General. Valid Excel dates should display as serial numbers rather than date text.
    3/ Test with a simple example:
    =STOCKHISTORY("AAPL",DATE(2024,1,1),DATE(2024,1,31))
    and compare the result to:
    If applicable, specify the exchange explicitly:
    =STOCKHISTORY("XNAS:AAPL",A1,B1)
    For retrieving the closing price on a specific date stored in a cell, you can use:
    =INDEX(STOCKHISTORY("AAPL",C1,C1,0,0),1,2)
    where C1 contains the target date.
    For reference STOCKHISTORY function
    I hope information above meet your expectations, feel free to reach out if you have any other questions.
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in the forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
