Certificate not generated for AZ-305 - Designing Microsoft Azure Infrastructure Solutions
Rakesh Meshram 0 Reputation points
2026-09-11T05:46:58.9233333+00:00
I have passed the exam for AZ-305 - Designing Microsoft Azure Infrastructure Solutions , I am not seeing certificate for the same . I can see the exam details in past exam section but not seeing certificate in certificate section.
{D994AC34-8892-48F0-951A-94E73CE8056D}
{10BDD556-EB0C-4737-9D34-0FFD80BFBF42}
  1. TP 163.1K Reputation points Volunteer Moderator
    2026-09-11T05:56:27.22+00:00
    In addition to passing AZ-305 exam you must also have Active Azure Administrator Associate (AZ-104) certification. Since this certification isn't in your screenshot you will need to pass AZ-104 exam and then both certifications will show up.
    Please click Accept Answer if the above was helpful.
    Thanks.
    -TP
