Surface laptop 4 power button does not work
Al Bergsma 0 Reputation points
2026-09-11T01:53:09.2466667+00:00
Surface laptop 4 would work (wake from sleep with open lid) but will not power on once shutdown, suspet power button. Any suggestions? Have ensured it has power, tried it on surface dock, but will not power on.
Surface | Surface Laptop | Power and battery
AI answer
2026-09-11T01:53:21.1166667+00:00
Since the Surface Laptop 4 wakes from sleep when the lid is opened but does not start after a full shutdown, use the documented startup recovery steps in this order:
  1. Disconnect everything connected to the device.
    • Remove USB devices, SD cards, external monitors, Type Cover, and any dock connection.
    • If connected to Surface Dock, unplug the laptop from the dock and try powering it on directly.
    • A connected accessory can prevent startup.
  2. Connect the power supply designed for the Surface.
    • Charge it for at least 15 minutes.
    • Then close and reopen the lid and press the power button.
  3. Try the keyboard wake shortcut.
    • Connect to a keyboard or use the integrated keyboard.
    • Press Windows logo key + Ctrl + Shift + B.
  4. Force a shutdown and restart.
    • For Surface Laptop 4, press and hold the power button until the device shuts down and restarts and the Windows logo appears, which takes about 20 seconds.
    • Then release the power button.
  5. If the device starts after that, install the latest Surface and Windows updates.
  6. If it still will not start, use a service option.
    • Microsoft support lists options including sending the device to Microsoft, finding in-person support where available, or self-repair information for technically experienced users.
A normal shutdown method, when available, is Start > Power > Shut down. Holding the power button for 4 seconds and swiping down is also listed, and if that does not work, holding it until the screen turns off takes about 10 seconds. For an unresponsive Surface Laptop 4, the 20-second forced restart is the documented recovery step.
2 additional answers
  1. Idham Zulhendy 0 Reputation points
    2026-09-11T10:41:13.63+00:00
    To isolate whether this issue is caused by a faulty physical power button or a power management/firmware glitch, follow these structured troubleshooting steps based on Microsoft Support and community guidelines:
    Step 1: Perform the Power State Test
    Since opening the lid wakes the machine from sleep, perform this test to narrow down the cause:
    Wake the laptop by opening the lid.
    Click Start > Power > Restart (do not choose Shut Down).
    Observe the behavior:
    If it successfully restarts: The core motherboard and power delivery circuits are functional. The issue is highly likely a failed physical power button key/switch or cold-boot firmware signal.
      __If it fails to restart or gets stuck:__ The issue points toward motherboard power management circuitry or firmware corruption rather than just the physical button.
    Step 2: Clear Peripheral Conflicts
    Disconnect all connected peripherals, including external monitors, USB drives, SD cards, and the Surface Dock.
    Plug the original Surface OEM power charger directly into the laptop (avoid using the Dock while troubleshooting).
    Charge the device continuously for at least 15 minutes.
    Step 3: Force a Hardware/EC Power Reset
    A stuck Embedded Controller (EC) can prevent a cold boot even if the power button signal reaches it.
    20-Second Force Reset: Press and hold the Power Button continuously for at least 20 to 30 seconds, even if the screen remains black, to force a reset of the power circuitry. Release the button and wait 10 seconds, then try a short press.
    Two-Button Reset Combo: Unplug the power cable, then press and hold Power + Volume Up together for 15 to 20 seconds. Release both buttons, wait 10 seconds, reconnect the power supply, and attempt to turn it on.
    Display Driver Wake Shortcut: While the laptop is plugged in, press Windows Key + Ctrl + Shift + B on the integrated keyboard to reset the display pipeline.
    Next Steps
    If the laptop restarts via software but the power button never responds: The keyboard assembly (which houses the power key on the Surface Laptop 4) likely needs physical replacement.
    • If no power combinations work: Check your device's warranty status by serial number on the Microsoft Support site to initiate a repair, service, or self-repair replacement option.To isolate whether this issue is caused by a faulty physical power button or a power management/firmware glitch, follow these structured troubleshooting steps based on Microsoft Support and community guidelines:
      1. Wake the laptop by opening the lid.
      2. Click Start > Power > Restart (do not choose Shut Down).
      3. Observe the behavior:
        • If it successfully restarts: The core motherboard and power delivery circuits are functional. The issue is highly likely a failed physical power button key/switch or cold-boot firmware signal.
        • If it fails to restart or gets stuck: The issue points toward motherboard power management circuitry or firmware corruption rather than just the physical button.
      1. Disconnect all connected peripherals, including external monitors, USB drives, SD cards, and the Surface Dock.
      2. Plug the original Surface OEM power charger directly into the laptop (avoid using the Dock while troubleshooting).
      3. Charge the device continuously for at least 15 minutes.
      1. 20-Second Force Reset: Press and hold the Power Button continuously for at least 20 to 30 seconds, even if the screen remains black, to force a reset of the power circuitry. Release the button and wait 10 seconds, then try a short press.
      2. Two-Button Reset Combo: Unplug the power cable, then press and hold Power + Volume Up together for 15 to 20 seconds. Release both buttons, wait 10 seconds, reconnect the power supply, and attempt to turn it on.
      3. Display Driver Wake Shortcut: While the laptop is plugged in, press Windows Key + Ctrl + Shift + B on the integrated keyboard to reset the display pipeline.
      Next Steps
      • If the laptop restarts via software but the power button never responds: The keyboard assembly (which houses the power key on the Surface Laptop 4) likely needs physical replacement.
  2. S.Sengupta 32,031 Reputation points MVP Volunteer Moderator
    2026-09-11T02:02:35.44+00:00
    Yes, the power button is a reasonable suspect, but I wouldn't conclude that yet. The fact that your Surface Laptop 4 wakes when you open the lid tells us that the machine can come out of sleep, but a cold boot after Shut down is a different process.
    The most useful test is:
    Start the laptop if you can by opening the lid.
    Choose Restart from Windows.
    See whether it successfully restarts.
    Then, after it is running again, shut it down completely and try the power button.
    If Restart works but Power-on after Shut down doesn't: power-button/cold-boot firmware circuitry becomes quite suspicious.
    If even Restart fails: I'd look more toward firmware/motherboard/power-management issues.
    Also try Power + Volume Up for 15–20 seconds with the charger disconnected, then release and press Power normally. Plug into power, then press and hold the power button for 20-30 seconds (not the usual 3-4 sec), even if nothing appears to happen. This forces a hardware reset of the power management circuitry, not just a normal press.
    Release, wait 10 seconds, then press the power button normally to boot.
    If the 30-second forced hold doesn't bring it back at all (no lights, no fan, nothing), I'd go ahead and start a Microsoft Support / Surface warranty check — worth checking your device's warranty status by serial number before doing anything more invasive.
