power automate in excel
Jessie Red 0 Reputation points
2026-09-10T21:19:40.49+00:00
how do i enable power automate in excel since i want excel to automate sending emails for me
Microsoft 365 and Office | Excel | For business | Other
    2026-09-10T21:19:53.37+00:00
    To use Power Automate from Excel, open the workbook in Excel and use the Automate tab.
    1. Open the Excel workbook.
    2. On the ribbon, select Automate.
    3. Choose Automate Work or Automate a Task.
    4. Pick a prebuilt template, or start a flow that connects Excel with Outlook or another service.
    5. Follow the prompts to sign in and create any required connections.
    6. Select Create flow.
    If the Automate tab does not appear, access to Office Scripts and Power Automate is required.
    For sending emails automatically, Power Automate can run on a schedule or when an event happens. A common pattern is:
    1. In Power Automate, select Create.
    2. Choose Automated flow for event-based email sending, or Scheduled cloud flow for recurring reminders.
    3. Add the Excel step if needed, such as Excel Online (Business) – Run script.
    4. Add Office 365 Outlook – Send an email (V2).
    5. Save the flow.
    If a connection is missing:
    1. Sign in to Power Automate.
    2. Go to Data > Connections.
    3. Select New connection.
    4. Choose the connector, such as Excel, OneDrive for Business, or Microsoft 365 Outlook.
    5. Sign in to complete the connection.
    All flows created from Excel are created in the default environment.
  2. Lin v 1,205 Reputation points Independent Advisor
    2026-09-10T22:00:16.8766667+00:00
    Hi Jessie,
    The Automate tab in Excel is the area where Excel's automation features are available, including Office Scripts and integration with Power Automate. Office Scripts can automate repetitive tasks in Excel, and those scripts can also be connected to Power Automate flows for scenarios such as sending emails automatically.
    However, if you do not see the Automate tab, you may try following the guidance in Introduction to Office Scripts in Excel, which has a troubleshooting section titled "Automate tab not appearing or Office Scripts unavailable".
    Regarding your request to automate sending emails, since this forum category primarily focuses on Microsoft 365 and Office applications, and your question relates specifically to Microsoft Power Automate, I want to help point you to the most appropriate support channel for this topic.
    If you need guidance on creating or configuring an email automation workflow, I recommend posting your question in the Power Automate community where members specialize in Power Automate scenarios and can provide more detailed assistance.
    I hope this information is helpful. Feel free to let me know if you have any questions.
