ok can someone else help me please
How to fix my sound input as my speaker sound is not working
I have attended calls today on zoom and teams and speakers are not able to hear me when I talk. Help
Ferdinand Nanalig 32,835 Reputation points Independent Advisor2026-09-10T20:09:54.3666667+00:00 Hi, let me help you.
It seems that you are having problems with your laptop's internal microphone.
Please follow the steps below;
Please hover your mouse over the sound icon in the lower-right corner, then right-click it and select Troubleshoot Sound. Let the troubleshooter finish its task; this should either resolve the problem or display an error message.
If that doesn't work, we need to remove the Audio driver from Device Manager and restart the PC to reinstall it.
Here are the steps to completely remove a Device from your computer.
Step 1. Use the Windows key + X shortcut.
Step 2. Select Device Manager.
Step 3. Expand the entry Sound, Video, and Game Controllers. Right-click the problematic device, which is either Realtek Audio, or AMD High-definition Audio, or High-Definition Audio, depending on the audio device installed in your PC, and select Uninstall device.
Step 4. You need to check the option Delete the driver software for this device and then click the Uninstall button.
Step 5. Reboot the computer.
After the reboot, please see if the problem is fixed.
If that still does not work, please visit the support website of your laptop or desktop and then download and install the latest Audio driver, then restart the PC.
