Surface Pro 6 – Bootable Operating System Not Found
Shivam Prajapati 0 Reputation points
2026-09-10T18:42:49.01+00:00
Dear Microsoft Support Team,
I am facing a boot issue with a Microsoft Surface Pro 6.
The device is showing the following error:
“Couldn't find a bootable operating system.”
I have performed some non-destructive checks:
  • Windows Boot Manager and Internal Storage are visible in Surface UEFI.
  • Windows Recovery USB boots successfully.
  • However, in Windows Recovery Command Prompt, DiskPart does not detect the internal SSD.
  • WMIC also detects only the USB flash drive, not the internal SSD.
  • No formatting, partition deletion, clean, reset, or Windows reinstallation has been performed.
The device contains important official data, so data preservation is extremely important.
Please advise on the non-destructive diagnostic and recovery procedure. We do not want to reset, format, reinstall Windows, or modify/delete any existing partitions without confirming the impact on the data.
Kindly let us know the next recommended steps and whether the device requires hardware-level diagnosis.
Regards, Shivamimage
WhatsApp Image 2026-09-09 at 5.10.37 PM
    2026-09-10T18:43:16.38+00:00
    The current findings point to storage-level failure or loss of SSD visibility rather than a normal boot configuration issue.
    Given these facts:
    • Windows Boot Manager and Internal Storage appear in Surface UEFI
    • the USB recovery drive boots successfully
    • DiskPart and WMIC in Windows Recovery do not detect the internal SSD
    • no reset, reinstall, formatting, or partition deletion has been performed
    The next recommended non-destructive path is:
    1. Re-check Surface UEFI boot configuration
      • In Surface UEFI, open Boot configuration.
      • Confirm that valid boot options are enabled. Microsoft states that Windows Boot Manager, Internal Storage, USB Storage, and PXE Network should be selected by default.
      • This confirms the device is not blocked by a disabled boot entry.
    2. Perform a forced restart
      • Press and hold the power button until Surface restarts and the Windows logo appears, which can take about 20 seconds.
      • This is a non-destructive step and is the recommended restart method for this condition.
    3. Use the Surface recovery USB only for startup diagnostics, not reset
      • Since the recovery USB already boots, that confirms the device can start external recovery media.
      • Do not choose reset or recovery actions if data preservation is required.
    4. If USB recovery media ever stops booting, verify USB boot prerequisites
      • Ensure boot-from-USB is enabled in Surface BIOS/UEFI.
      • If needed, configure the boot order so USB is first.
      • Check Secure Boot configuration, because newer Surface recovery images require the 2023 Secure Boot certificate.
    5. Treat lack of SSD detection in WinRE as a hardware-diagnosis trigger
      • When recovery tools detect only the USB drive and not the internal SSD, there is no supported non-destructive software repair step in the provided guidance to rebuild Windows from that state.
      • At that point, the next recommended step is hardware-level diagnosis / service rather than reset or reinstall.
    6. Escalate to service options
      • If the documented checks do not resolve the problem, Microsoft’s next path is self-repair, send to Microsoft, or in-person support where available.
      • For a device containing important official data, avoid any action that writes to the internal drive until hardware assessment is completed.
    Based on the documented guidance and the reported SSD non-detection, hardware-level diagnosis is warranted.
