Hi Michael,
The application exception is very generic, and we can't directly pinpoint the cause.
Do you see any application name that could be the cause?
Does the issue persist in a clean boot state?
Type “msconfig” (without quotes) and press Enter.
In the System Configuration window, select the Services tab.
Check the box next to “Hide all Microsoft services”. Ensure you do it carefully, and not disable all Microsoft services.
Click on “Disable all”.
Select the Startup tab and click on “Open Task Manager”.
In the Task Manager window, select each startup item and click on “Disable”.
Close Task Manager and click on OK in the System Configuration window.
- Restart your computer.
More details: https://aka.ms/wincleanboot
I look forward to hearing from you to get the results of the troubleshooting.
