Other issues or features related to Microsoft Edge on Windows 11
When I am online and want to watch a YouTube video or typing a message to you now, I get these pop ups showing inspect, back, translate and other options and I can't get it to stop. Is this an issue with Windows 11 or Edge? Did the latest update have a glitch in it.
Please help
AI answer
This is more likely an Edge setting, extension, or browsing-data issue than a known Windows 11 update glitch based on the available guidance.
Try these steps in order:
If the issue continues after these steps, Edge can also be repaired from: Start > Settings > Apps > Installed apps > Microsoft Edge > Modify > Repair
The menu showing "Inspect," "Back," "Translate," and similar options is the right-click menu in Edge. If it is appearing without you right-clicking, the mouse or touchpad may be triggering it.
Try these first:
To help narrow this down:
edge://settings/help and let me know the version number shown there.Click "Add comment" to let me know.
Thanks!
My extensions are turned off and so far no more pop ups. I hope it continues. I will also clear my browsing history. I appreciate your help.I use Avast VPN, clean up, breach guard and driver update.
