Not receiving emails
Amy Payne 0 Reputation points
2026-09-07T22:23:35.8233333+00:00
I was hacked and I changed my password but I am not receiving emails. I only receive junk mail. How can I fix it
    2026-09-07T22:23:49.7866667+00:00
    1. In Outlook.com, check whether messages are being redirected instead of delivered to Inbox:
      • Settings > Mail > Rules and delete any rule that was not created intentionally.
      • Check Forwarding and make sure mail is not being forwarded elsewhere.
      • Check whether IMAP or POP is enabled for a connected app and disable them if they are causing issues.
    2. Check folders and filters that can hide mail:
      • Open the Other tab.
      • Check the Junk Email folder and Junk Email settings.
      • If messages are in Junk but should not be, right-click them and choose Mark as not junk.
      • Restore sorting with Filter > Sort > Date.
    3. Check whether mailbox storage is full. If Microsoft cloud storage is full, Outlook.com cannot send or receive email, and messages sent during that time are bounced back and unrecoverable.
    4. Review account security after the compromise:
      • Use the sign-in helper if needed.
      • Check account settings such as connected accounts, forwarding, and automatic replies.
      • If the account was hacked, run a full antivirus scan on the PC before changing the password again, then change or reset the password.
    5. If only one device is affected, remove the partnership between that device and the mailbox to fix sync issues.
    6. If mail from blocked senders is still appearing in Inbox, the sender may be changing addresses or hiding the real address. Check message headers and update the blocked senders list or create an inbox rule.
  2. Thomas4-N 21,535 Reputation points Microsoft External Staff Moderator
    2026-09-10T07:00:08.7933333+00:00
    Hello Amy Payne,
    Since this started right after the account was hacked, I would first check whether anything was changed in your mailbox settings.
    Please sign in to Outlook.com in a browser and check Settings > Mail > Rules and Forwarding. Remove anything you don't recognize or didn't create yourself.
    After that, send a test email to the account from another email address. If it still doesn't arrive, does the sender receive a bounce-back or error message? If so, please share the exact error message, without including any personal information.
    That should help narrow down whether emails are being redirected or whether there is a separate delivery issue.
