Need help finding Drivers for Vulcan Excursion XB (VTA1005XB) - Windows 8.1 (Audio & Camera not working)
ahmed 0 Reputation points
2026-09-07T19:58:57.36+00:00
Hello everyone,
I have an older tablet: Vulcan Excursion XB (Model: VTA1005XB) running Windows 8.1 (32-bit). It is powered by an Intel Atom Z3735F processor.
Currently, the Audio (Sound) and the Camera are not working at all. They are missing from the Device Manager, and I cannot find the official drivers anywhere online since the manufacturer's website is down.
Could anyone please guide me or share a link to the original drivers/chipset package for this specific tablet model?
Thank you in advance!
  1. MR_MEOW 3,706 Reputation points
    2026-09-07T21:00:28.4933333+00:00
    Hello, Well only thing I can think of is to look at the archives. https://archive.org/details/software
    This is "as-is no warranty use at own risk" website. The users like me up load there old files for others to use. It may not even be on there but it might be. If it is not on this web site then its most likely not findable. The odd one would be to call a small repair computer store they "might" have the software. The other one too is If you have the recovery cd-rom it should be on that cd-rom.
  2. Deleted
  3. _AW_ 69,496 Reputation points Volunteer Moderator
    2026-09-08T11:26:09.28+00:00
    As all manufacturer links seem to be dead, you'll need to try third party suppliers. There's a large collection linked below. If you try them, set a system restore point before installing.
    https://www.mediafire.com/folder/1ro6i5ur83n4t/Drivers+Vulcan+Excursion+XB
