​Metro Online Gift Card Out of Stock for 8 Months in Pakistan – Update or Daraz Alternative Needed
Rehan Amir 0 Reputation points
2026-09-07T14:26:22.2533333+00:00
​​I am writing to bring urgent attention to a persistent issue with the Microsoft Rewards catalog for users in Pakistan. The Metro Online Gift Card has been completely out of stock for the past 7 to 8 months continuously. Leaving a primary regional reward option unavailable for over half a year severely impacts the credibility of the program in Pakistan.
​Standard automated replies advising us to "check back later" are no longer sufficient given this long delay. We need a definitive response from the support team on the following points:
​Restock Timeline: Is there an official schedule for restocking the Metro Online voucher, or has this reward been permanently discontinued in Pakistan?
​Alternative Options: If Metro Online cannot be restocked, can Microsoft consider adding another major local e-commerce partner—such as Daraz.pk—so Pakistani users can actually redeem their hard-earned points?
​Please provide a clear and direct update on regional stock replenishment instead of a generic template reply. Thank you.
Bing | Microsoft Rewards
  1. paulr0511 48,455 Reputation points Independent Advisor
    2026-09-07T16:05:23.6366667+00:00
    Hello, good day and thanks for your question. Sorry to know about this and if a certain reward is not available it means that the code for it has became out of stock and therefore there is no exact timeframe on when it will be replenished as this is not usually announced but the rewards team will be doing it’s best for it to be back the soonest on whichever amount will be available. In the meantime, you may continue to do activities and tasks to be able earn and save points to be able to use once the preferred reward that you are after becomes available then you have the points to possibly redeem it more than once.
    High Demand
    • As these type of rewards requires a relatively low number of points, it is one of the most redeemed rewards which is causing for it to go out of stock so quickly.
    Limited Inventory
    • Due to a limited number of these type of rewards being released. Once the quota is reached for a certain period, then the reward goes out of stock until it is replenished or has become available again.
    Regional Availability
    • The availability of these type of rewards might also vary by region. There are certain regions that has a higher demand or has limited availability, which can also result in the out of stock prompt during redemption.
