How to create and format an outline template in Word (for Mac)
MKH 0 Reputation points
2026-09-06T17:13:15.3566667+00:00
Earlier this year I created an outline from Word's pre-made template (I believe) ... it was great. When I would hit Enter, the next level appeared ... if I hit enter, enter the text would revert to a higher level ... and if, instead, I hit Enter+Tab, the next line would be the level below.
For some reason, the enter+tab option is not working to advance to a lower level on the outline. I am desperate to figure out how to that to work again. (law school student starting to create all my course outline.)
Any help would be greatly appreciated.
Microsoft 365 and Office | Word | Other | MacOS
  1. Bob Jones AKA CyberTaz MVP 437.7K Reputation points
    2026-09-07T14:47:57.3933333+00:00
    For what you are describing it might be worth your while to use Outline View. Outline View is a standard feature of the program with no template needed. Please see these definitive articles:
    Outline - Rado
    Outlining - Kenyon
    The articles are based on illustrations in Word for Windows but Outline View in Mac Word is virtually identical.
    BTW: Charles Kenyon is an attorney.
  2. Stefan Blom 351.3K Reputation points MVP Volunteer Moderator
    2026-09-06T18:20:23.59+00:00
    You should be able to use Tab and Shift+Tab for demoting and promoting list levels.
  3. AI answer
    2026-09-06T17:13:28.6433333+00:00
    Use Outline view for this behavior.
    1. In Word, open the document and select View > Outline.
    2. In Outline view, create the structure using heading levels:
      • Level 1 for main topics
      • Level 2 for subpoints
    3. When the document is in Outline view:
      • Press Enter at the end of a heading to insert another heading at the same level.
      • To move a heading to a lower level (demote it), press Alt+Shift+Right Arrow.
      • To move a heading to a higher level (promote it), press Alt+Shift+Left Arrow.
    4. If subtopics are needed under a main item, type the main item, press Enter, then use the demote command to make the next line a lower-level heading.
    5. When finished, select Close Outline View.
    If the document is not in Outline view, the Enter behavior will not match outline editing. One accepted Microsoft Q&A answer for this exact symptom states that in Outline view, pressing Enter at the end of a heading inserts another heading at the same level, and the view provides easy promote/demote controls.
