Installing or updating Microsoft Edge on Windows 11
While i click microsoft edge it does not launch. At setting i updated microsoft edge but still does not launch
AI answer
Try these steps in order. After each step, start Edge again and check whether it opens.
"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --user-data-dir="%TEMP%\edge-test-profile"
Hi, good day!
To help narrow down the cause
When you click Microsoft Edge, does it appear on the taskbar but not show on the desktop screen?
Have you already tried the AI-suggested troubleshooting steps?
Do you have a secondary monitor connected? If so, please try disconnecting it and see if the issue persists.
If this doesn't work, open Microsoft Edge then Press and Hold the Shift key on your keyboard. Right click the affected application on the taskbar. Select Move then use the left and right arrows on your keyboard to move to the center.
I look forward to receiving your update and I'm willing to collaborate with you till we resolve the issue. Do keep me informed by clicking "Add comment" below.
