No lifting power point slides
Kathyrn Rodriguez 0 Reputation points
2026-09-05T20:50:24.8633333+00:00
I have tried every suggestion. My power point on my iPad no longer allows slides to be moved to different position. When I press and hold the slide does not lift.
Microsoft 365 and Office | PowerPoint | For home | iOS
  1. Norah-L 10,580 Reputation points Microsoft External Staff Moderator
    2026-09-06T02:36:50.4466667+00:00
    Hello Kathyrn Rodriguez,
    I understand that PowerPoint on your iPad no longer responds when you press and hold a slide thumbnail, so you cannot drag it to another position. Since the usual gesture has stopped working, this may be an app or touch-response issue rather than a problem with the presentation itself.
    Please try the options below and check whether the issue continues:
    1. Open a new blank presentation and try moving a slide there. This helps determine whether the problem affects PowerPoint generally or only that file.
    2. Close PowerPoint completely from the iPad app switcher, restart the iPad, and test again.
    3. Check the App Store for a PowerPoint update and install any available iPadOS update.
    4. If the issue continues, remove and reinstall PowerPoint. First confirm that your presentations are saved to OneDrive or another safe location.
    5. As a temporary workaround, open the presentation in PowerPoint for the web or on another device and rearrange the slides there.
    If the gesture remains unavailable after reinstalling, please send feedback from PowerPoint profile picture > Help & Feedback and include the iPad model, iPadOS version, PowerPoint version, and a short screen recording. This sends the report directly to the relevant PowerPoint product team so they can investigate the issue further.
    Since this is a user-to-user support forum. Moderators, contributors including external Microsoft employees cannot directly intervene in Microsoft product features or access back-end systems. Our role is limited to providing technical guidance on reported issues, requests, or ideas.
