Azure DevOps: Login and Authentication Issues — Tenant and Session Conflicts
RyanJagdfeld-4166 0 Reputation points
2026-09-04T15:10:59.6866667+00:00
Problem description
I am unable to log in to my organization's Azure DevOps Services account. When accessing via the Azure portal, I encounter a 500 Internal Server Error, and direct navigation to the organization URL results in a 401 Unauthorized error, despite holding Owner/Admin permissions. I suspect there is a tenant or identity mismatch due to multiple accounts and session tokens.
Environment
Azure DevOps Services (public) organization on the VisualStudio.com domain, located in the US region.
What I've already tried
I cleared all cached sessions and signed out completely, then attempted to log in again. I used private browsing modes and different browsers to eliminate session conflicts. I also verified tenant IDs in Azure portal and attempted login via CLI with device code, which failed due to 'invalid_grant' errors. I reviewed account and tenant information in Azure AD and Azure portal, noticing multiple accounts associated with different tenants.
Current status
Currently, I am still unable to access my Azure DevOps organization due to persistent 500 and 401 errors. I seek guidance on resolving tenant or session conflicts, specifically how to clear residual session tokens, re-link directories, and ensure proper account sign-in to regain access.
Azure DevOps
  1. Tejaswini Billakurthi 270 Reputation points Microsoft External Staff Moderator
    2026-09-04T15:42:02.5866667+00:00
    Hello @RyanJagdfeld-4166
    Thank you for reaching out to Microsoft Q & A!
    Based on the reported symptoms, including the 500 Internal Server Error when accessing Azure DevOps through the Azure portal, the 401 Unauthorized error when accessing the Azure DevOps organization directly, and the authentication failures encountered during sign-in, the issue may be related to an identity or tenant association mismatch between the Azure DevOps organization and Microsoft Entra ID.
    Please verify that you are signing in with the exact User Principal Name (UPN) associated with your Azure DevOps identity, as Azure DevOps uses the UPN for Microsoft Entra authentication and does not support authentication through email aliases.
    If the Azure DevOps organization is connected to Microsoft Entra ID, ensure that the sign-in account belongs to the same tenant that the organization is associated with. Multiple accounts across different tenants or account-type mismatches can result in authentication failures and authorization errors.
    Additionally, if there have been any recent changes such as a UPN change, domain change, tenant migration, account recreation, or Azure DevOps organization directory reassociation, please share those details, as they may help identify the root cause.
    For additional guidance, please refer to the following Microsoft documentation:
    Please "Accept the Answer" if this information helped you. This will help us and others in the community as well.
