Click to Do not updating/not working
Paras Sharma 0 Reputation points
2026-09-04T12:33:09.5566667+00:00
Unable to use Click to Do, every time I start it. It displays 'couldn't update Click to Do, Click to Do needs a few more updates before it is ready to use". Left my laptop running for a few hours, tried using it to no avail. Rebooted it, didn't work. I thought maybe my wifi was tweaking, that wasn't it. Thought I forgot an update that wasn't it either. Clicking retry flashes a similar dialogue box for a millisecond which says we are getting a few things ready for Click to Do. Please keep you PC connected to the Internet and Check back soon. I review a lot of docs so click to do is really essential to my day-to-day.
any ideas as to what can fix this?
oh My Device is a Galaxy Book 5 Pro, 10 months old and it has all the requirements needed for click to do.click to do
Windows for home | Windows 11 | Apps
  1. Emma1-N 12,445 Reputation points Microsoft External Staff Moderator
    2026-09-05T00:11:59.17+00:00
    Hello Paras Sharma,
    Thank you for providing the details. Since your Galaxy Book 5 Pro meets the hardware requirements and Windows Update is already reporting that the PC is fully up to date, I would like to narrow this down a little further.
    Could you please confirm the following:
    • Are you signed in with a personal Microsoft account or a work/school account?
    • Which Windows 11 version are you running? Press Windows + R, type winver, and share the version shown.
    • Under Settings > Windows Update > Update history, do you see any recent failed updates?
    • Have you already tried opening Microsoft Store > Library > Get updates and allowing any available app updates to install?
    In the meantime, please try these quick checks:
    • Open Microsoft Store > Library and select Get updates
    • Open Settings > Windows Update and select Check for updates, then install all available updates, including optional updates.
    • Restart the PC after all updates finish, even if Windows does not specifically request a restart.
    • Try launching Click to Do again after the restart.
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
