Azure VMware Solution: Clarification on Licensing Model and Billing Records — License-Included PayGo Transition
Amir DIMRRY (MatchPoint IT LTD) 20 Reputation points Microsoft External Staff
2026-09-03T11:20:59.2066667+00:00
Problem description
I am seeking clarification on the current licensing and billing status of my Azure VMware Solution private cloud. Specifically, I want to confirm whether it is operating under License-Included PayGo, Reserved Instances, or another entitlement, and understand why there are no visible consumption or billing records in the Cost Management + Billing portal for this resource.
Environment
Azure VMware Solution private cloud in the region not specified; cluster size: three hosts (AV36); Portable VCF (BYOL) configuration: Not configured.
What I've already tried
I reviewed the Azure portal's private cloud blades, checked the Portable VCF page which shows 'Not configured,' inspected the Overview/Properties for licensing or billing metadata with no findings, examined Cost Management + Billing for any consumption records related to this cloud, and engaged support support. Additionally, I used Azure CLI commands to show the private cloud's SKU name, which is 'av36', and checked the billing records, which do not show any consumption for this resource.
Current status
I am looking for guidance on whether any action is required from my side regarding the upcoming SKU retirement, and how to determine the current licensing model and billing status of my private cloud.
  1. Allan Solomon Mejia 7,995 Reputation points
    2026-09-03T21:35:23.43+00:00
    Hello @Amir DIMRRY (MatchPoint IT LTD)
    The av36 SKU alone isn't enough to determine whether your three hosts are currently using license-included PayGo, a license-included Reserved Instance, or Portable VCF (BYOL). The key details are when you deployed the hosts and whether an AVS reservation currently covers them.
    Microsoft's current licensing guidance states that new Azure VMware Solution deployments since November 1, 2025 must use Portable VCF purchased from Broadcom. However, existing license-included deployments have transition periods. In particular, license-included PayGo deployments must transition to Portable VCF by October 31, 2026, while hosts covered by an active license-included Reserved Instance can remain covered until the applicable RI transition deadline/expiration.
    Since your Portable VCF (BYOL) page shows Not configured, first verify the billing arrangement before configuring a VCF key.
    1. Check the Azure portal > Reservations and determine whether an Azure VMware Solution reservation exists for the subscription/billing scope and whether its quantity covers all three AV36 hosts. Reservation scope matters because the reservation can be scoped to a resource group, subscription, management group, or shared billing scope.
    2. Confirm the original deployment/addition dates of the three hosts. This is particularly important for determining whether the environment qualifies as an existing license-included deployment.
    3. In Cost Management + Billing > Cost analysis, expand the scope beyond the AVS resource and check the billing subscription/account that contains the reservation. With reservations, matching usage can have an effective price of zero, so looking only for charges against the private-cloud resource can be misleading.
    4. If there is no applicable AVS reservation and these are legacy license-included PayGo hosts, plan the Portable VCF transition before October 31, 2026. Portable VCF is registered per private cloud under Manage > Portable VCF (BYOL). Once you register the Broadcom entitlement details, switch existing applicable hosts to Portable VCF pricing.
    Do not configure Portable VCF simply because the portal says “Not configured.” First establish whether the three hosts are currently covered by a license-included RI or legacy PayGo entitlement. Existing VCF-included hosts can remain covered under qualifying license-included reservations or legacy PayGo conditions during the transition period.
    The absence of visible consumption records is therefore worth investigating separately with the billing scope/RI information. If Cost Management still shows no AVS usage or reservation application at the billing-account level, I'd ask Microsoft Support to confirm the private cloud's backend billing meter/SKU, entitlement type, host deployment dates, and reservation benefit assignment rather than making a licensing change based solely on the portal blades.
    Sharing these references with you:
    Portable VCF licensing reference for Azure VMware Solution
    Configure Portable VCF for Azure VMware Solution
    Azure VMware Solution license-included service retirement
    Azure VMware Solution Reserved Instances
    Help make this community better for everyone: if this answer resolved your issue, please accept it or upvote it. If not, share more details in a comment so we can continue the discussion and find the right solution.
