A high-performance, durable block storage designed to be used with Azure Virtual Machines and Azure VMware Solution.
Azure schedules service retirements and automatic backend operations using UTC, typically beginning at 00:00 UTC on the stated date. However, automatic rollouts for large-scale infrastructure changes happen progressively rather than as an instantaneous global switch at exactly 00:00:00 UTC.
The retirement and subsequent automated processes take effect immediately after the date passes, meaning the very start of 8 September 2028 (00:00 UTC) marks the end of the support window.
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
