A Microsoft file hosting and synchronization service.
On Windows 11, OneDrive is usually already installed. For a new PC where Microsoft 365 is installed but OneDrive is missing or the browser download keeps failing, use this order:
- Check whether OneDrive is already on the PC.
- Open Start and search for OneDrive.
- If found, open it and sign in with the Microsoft 365 work or school account.
- If OneDrive is listed but not working, reinstall it.
- Open Start > type Programs > select Add or remove programs.
- Under Apps & features, find Microsoft OneDrive.
- Select it and choose Uninstall.
- This does not delete OneDrive data. The local folder stops syncing, but files remain available in OneDrive online.
- Download the sync app and install it: download the Microsoft OneDrive app from the website.
- Open the downloaded file, then sign in and complete setup.
- During setup, confirm these screens:
- This is your OneDrive folder: select Next to keep the default location, or Change location if needed.
- All your files, ready and on-demand: select Next.
- After setup completes:
- OneDrive files should appear in File Explorer.
- The OneDrive cloud icon should appear on the Windows taskbar.
- If needed, choose which folders sync to the PC again, because reinstalling resets OneDrive settings and triggers a full sync.
- If the browser download is failing, try these checks:
- Confirm the internet connection is stable.
- Restart the router or try a different network.
- Temporarily disable antivirus or firewall protection, then try the download again. This reduces protection temporarily, so re-enable it after testing.
- Try downloading with a different browser.
- Clear the browser cache and cookies, then retry.
- If this is a work or school OneDrive and reinstall still fails, repair Office before trying again.
- Right-click Start.
- In Windows 11, select Installed apps.
- Select the Microsoft Office product and choose Modify.
- For Click-to-run, select Online Repair > Repair.
- For MSI-based installs, select Repair > Continue.
- If OneDrive for work or school still does not install or sync after repair and reinstall:
- Ask the IT administrator to create a Microsoft support incident.
- Technical support for work or school accounts can also go through the organization’s IT helpdesk or admin.
If Windows 11 is in S mode, Microsoft does not provide a OneDrive installer that works in S mode. The only option is to switch out of S mode, and that change cannot be undone.
- Reinstall OneDrive
- Sync your computer's files and folders with OneDrive
- Sync files with OneDrive in Windows
- Troubleshooting tips for downloading, installing, and updating Microsoft Edge
- Troubleshooting OneDrive for work or school sync issues
- "Something went wrong" error when you try to start a Microsoft 365 app
- Download OneDrive
- Windows 11 in s mode with microsoft 365 personal account but i cannot re-install onedrive from Store - Microsoft Q&A
