Changing from Bullets to Numbered list in same Word doc
bogbean 20 Reputation points
2026-09-02T20:19:05.8433333+00:00
Example of problem
Photo for context. I use a Word document to take notes for a textbook course. I use a multilevel bulleted list to do this, but sometimes I want to write down a numbered list within the same document. However, Word seems to have a memory of the numbered list when I make it, and then whenever I am again in that same indent level of the list, it auto-formats with a numbered list again. If I try to change it back to bullets, it highlights all of the list points and changes them all to bullets; I'm seemingly not able to only change some within a specified range.
I want to be able to choose ranges of the document to have numbered lists vs bullet points; I don't want a certain level of a multi-level list to be locked in as either numbers or bullets. Does anyone else deal with this, and is there a way to fix it?
Microsoft 365 and Office | Word | For business | Windows
Answer accepted by question author and recommended by moderator
Charles Kenyon 170.7K Reputation points Volunteer Moderator
2026-09-03T01:22:30.8333333+00:00
The way I would do this would be to set up two separate Mulitlevel List Styles, each with a corresponding multilevel list. Each level in these lists must be attached to a separate paragraph style. If each list has nine levels, you will need eighteen paragraph styles.
Resources:
To apply a given level, numbered or bulleted, you would apply the appropriate paragraph style.
9 additional answers
  1. Kai-L 19,050 Reputation points Microsoft External Staff Moderator
    2026-09-02T21:20:38.4933333+00:00
    Dear bogbean,
    Thank you for the screenshot, it shows the problem clearly. Both numbered groups sit at the same level of one multilevel list, so Word treats them as a single list definition. That is why selecting one number highlights them all, and why changing the format affects every item at that level. The fix is to make the second group a separate list rather than part of the first.
    1. Select only the paragraphs in the second numbered group. Select the text itself rather than clicking a number, as clicking a number selects the whole connected list.
    2. Right-click the first number in that group and choose Set Numbering Value.
    3. Tick Start new list, then set the value to 1.
    Once the groups are separated, you can format each one independently, including turning one back into bullets without affecting the other.
    For future sections, the same principle applies as you type:
    1. Press Enter after the bullet above, then press Tab to demote to the sub level.
    2. Turn off bullets with Home > Bullets, then apply Home > Numbering.
    3. Type your numbered items.
    4. After the last one, press Enter, then Shift + Tab to return to the bullet level and reapply your bullet format.
    5. If Word continues numbering from the previous group, use Set Numbering Value > Start new list again.
    It is a little tedious the first few times, but Start new list is the setting that gives you the independent ranges you are after.
    I hope this helps, and do let me know how you get on with it.
    If the answer is helpful, please click "Yes" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in the forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
