DFS Path Not Found with short domain names
John Doe 40 Reputation points
2026-09-02T17:16:03.02+00:00
Clients fail to access DFS targets using short domain names, receiving "The network path was not found." How do we configure DFSN to prefer fully qualified domain names (FQDNs) in referrals using Set-DfsnServerConfiguration?
Windows for business | Windows Server | Networking | Network connectivity and file sharing
Tracy Le 12,650 Reputation points Independent Advisor
2026-09-02T18:03:40.1966667+00:00
Hello John Doe,
The “Network path not found” error usually happens when DFS referrals return short NetBIOS names that clients cannot resolve, especially across forests or subnets. To fix this consistently, you should enforce fully qualified domain names (FQDNs) for all DFS Namespace referrals. On each namespace server hosting a root, run PowerShell as administrator and execute: Set-DfsnServerConfiguration -ComputerName <ServerName> -UseFqdn $true.
This command updates the registry (DfsDnsConfig = 1 under HKLM\SYSTEM\CurrentControlSet\Services\Dfs) so DFS always generates referrals with FQDNs. After applying the change, restart the DFS Namespace service using Restart-Service Dfs. On the client side, clear cached referrals with dfsutil cache referral flush and dfsutil cache domain flush, or simply reboot the workstation, to ensure fresh FQDN referrals are requested. For older domain-based namespaces created before enabling FQDN mode, you may need to update root metadata with dfsutil root registry or rebuild the root share if legacy referrals persist. This ensures reliable DFS access across your enterprise.
Tracy Le.
1 additional answer
    2026-09-02T17:16:13.96+00:00
    Use Set-DfsnServerConfiguration with the -UseFqdn Boolean parameter to make the DFS namespace root server provide referrals as fully qualified domain names instead of NETBIOS names.
    Example:
    Set-DfsnServerConfiguration -UseFqdn $true
    To verify the current server configuration before or after the change, use:
    Get-DfsnServerConfiguration
    This cmdlet changes settings on a DFS namespace root server, and -UseFqdn specifically controls whether referrals are returned as FQDNs or NETBIOS names.
