Uploading and maintaining product data feeds for shopping campaigns
Hello Shahzaib Khan,
Thank you for using our Microsoft Advertising Learn Q&A Platform!
I understand that you have successfully created and received approval for your Microsoft Merchant Center store and that you initiated a product import from your existing Google Merchant Center account approximately 48 hours ago. However, you are currently seeing 0 products in Microsoft Merchant Center.
Based on the information you provided, this is not the expected behavior. In most cases, products imported from Google Merchant Center should begin appearing in Microsoft Merchant Center within 24 hours after a successful import has been initiated.
To help determine whether the import was completed successfully, I recommend checking the following:
- Verify the feed in Microsoft Merchant Center
- Go to Merchant Center > Select your Store > Feeds.
- If the import was successfully created, you should see a feed named "Google Feed File" or a similar imported feed.
- If only the Default Catalog is displayed and no Google feed is present, this may indicate that the import was not successfully established.
- Check the Import section
- Navigate to Merchant Center > Select your Store > Import.
- Review whether there is an active or scheduled Google Merchant Center import.
- Check for any import status messages, errors, or failed import attempts.
Based on the information you provided, it appears that the import may not have completed successfully. If there are no products displayed in the Summary tab, no products listed in the Products tab, and no scheduled import running in the Import tab of your Merchant Center store, I recommend reinitiating the catalog import from Google Merchant Center.
A successful import should create an entry within the Import tab and once processed, the imported products should begin appearing within your Microsoft Merchant Center catalog.
Steps to reinitiate the Google Merchant Center import:
- Sign in to your Microsoft Advertising account.
- Navigate to Merchant Center.
- Select your approved Microsoft Merchant Center store.
- Open the Import tab within the store.
- Select Import from Google Merchant Center.
- Sign in to the Google account associated with your Google Merchant Center.
- Grant the required permissions when prompted.
- Select the Google Merchant Center account that contains your product catalog.
- Choose the appropriate country and target market settings for the import.
- Review the import settings and select Import or Save & Schedule.
- Once the import has been successfully created, an import entry should appear under the Import tab, where you can monitor its status and review any processing results or errors.
Import your Google Merchant Center product offers to Microsoft Merchant Center
I have also sent you a private message requesting some additional information so that we can better understand the situation and provide further assistance. When you have some time, please feel free to check the message and share the requested details. We'll be glad to review the information and assist you with the next steps.
Kind regards,
Chris | Microsoft Advertising Support Specialist | 1-800-518-5689
